Ir is the reverse current. When a diode is reverse biased with a voltage not in excess of the breakdown voltage, a small amount of current is able to flow. So, even though this is the ‘off’ state, there’s a non-zero current. Check out the I-V curve of a diode’s data sheet. In the reverse side, you’ll see a small jump from the voltage axis (x). That small bump is the Ir reading you’re seeing. As reverse voltage approaches the breakdown voltage (Vbr), the current begins to increase until it is essentially an open circuit.
