An update.
I audio probed the circuit in envelope mode and since I don't know I gotta ask.
I did not get any signal on either side of d2/3
No signal on either side of R11
No signal either side of C5.
I've got continuity on both sides of the switch
ok so I flip the switch to dist/fuzz I have signal on one lug on the switch (the lug I'd expect signal on) but no signal on the switch middle lug and still no signal on any of D2/3 , R11 or C5
No signal on D2/3 R11 and C5 when not in dist mode I kinda understand but obviously I've got no signal going into the distortin pathway? I'm thinking that's to be expected being of the distortion side. Am I correct?
So now I'm stuck.
When it was boxed there were a couple times I'd switch to the distortion just to see and there'd be a faint high pitched whistle that when switched back to just envelope it would be there too but really faint with a little extra white noise added in the effect still worked (but I don't think to it's full potential) Switching it a couple of times would remove it from the envelope side. Maybe the switch is bad? even if it shows correct continuity?
In distortion mode I get signal on lugs 2 & 3 of the sens pot which serves as the volume pot for the fuzz. As I turn the sens pot CW the signal increases on lug 2 of the sens pot. As it should (I assume}. lug 3 sounds so much brighter than 2 (better to my ears).
nnno clue now what to do with this info or where to go from here
ANY help, getting this to work at a 100%, will automatically get you much deserved appreciation. Some of you may not necessarily need that but I appreciate appreciation .........so......... THANKS PEDALPCB FORUM PEOPLE for all the good times and help. Hope we can do this one. more. time.
