Thanks man, think ive got it now. One of the bat48's wasnt seated properly. Jsut need to tune it now!I had the same problem on my build. I had to turn the Gate trimmer almost fully CW to get an effect. Maybe that‘s also the problem on yours.![]()
Yep, Good Catch, R34 definitely 330K , Should be 330 ohm = Orange, Orange, Black, Black. Brown.From a quick glance, pin 4 on your BBD doesn't look right.
Double check R34 there. Looks like you have a 330K? It should be a 330 ohm.
It's quite common when a PCB uses a 33 value to see 330 ohm, 3K3, 33K, 330K somewhere on the board!
Same with 47 value, 470 ohm, 4K7, 47K 470K!!!
One bloody colour Band different !!!
Thanks, i had missed that.The pinout of 2SK170 (through-hole equivalent of the 2SK208) is DGS, but the J201 pinout is DSG. I can't quite see from the photos, so make sure you've swapped the Gate & Source pins before placing it in the socket. To keep them from shorting out as you cross them over, you can use a piece of heat shrink tubing or a piece of stripped wire insulation on one lead.
i believe im having the same issue. i think its going to be regarding the gate area as there seems to be no real change to effect atall with that. this is the third ive
