Holy necrobump, batman!
My magnetron does the same thing - the modulation LED doesn't dim very much and when the depth is up its basically permanently lit.
Any ideas?
The depth knob affects the mod LED. The more depth, the brighter the light. The more you turn up the speed, the faster it blinks.
From what you’re describing, that sounds like normal behavior to me. My magnetron delay does the same thing. The light dims and brightens with the speed but doesn’t go completely out.Yes - mine does that - the issue is that the blinking barely goes *off*. It's like an LED that's permanently on, and dims slightly, rather than an LED that blinks on and off.
R103? The resistors only go up to 30 for this build.Mine goes completely dim (off) when the modulation level is at 0. And gets brighter as it gets turned up. It pulses along with the modulation rate.
You probably need to adjust R103 to control the light level. Depending on the type of LED you use, the stock 4K value may not be enough to tame the brightness.
mine only goes to r30Refer to the build doc. Components which are extra to the circuit like power filters and CLRs are usually labeled 101, 102, etc.View attachment 22438
Tie the cathode in with the led spot in the stomp switch. Ground is ground no matter where it’s soldered.I see multiples videos of the pedal where the LED flashes with the speed of the delay. Mine just stays solid, but dims with the depth.
It does not bother me really much, but what could be a mod for the led to stop when the pedal is disengaged ?
Thanks !
