Magnetron Very Low Output
Spiff4565
I had this working just fine but needed to put it in a different enclosure.
After removing it and hooking up power the Rate LED does not receive power and there is virtually no output.
Using a audio probe, on IC1, pin 2 I am getting a good strong signal. On pin 1 of IC1, the output is half of the signal going to pin 2.
Is this lower output on pin 1 expected or might there be another issue causing this?
Yes, working just fine. So good my brother wants to buy it, but wanted in a different enclosure and LED's arranged differently.
Lit foot switch for on/off and rate light off when unit is off.
You're gonna need to follow along with the schematic as you probe your signal.
IC1 PIN 1 is the output of the OPerational AMPlifier (1/2 of IC1). A stronger signal here is to be expected.
Could be a connection came loose somewhere as you were re-boxing. I'd carefully inspect any offboard wiring, potentiometer solder joints, jacks, etc. Maybe one of the DC blocking 1UF caps got nudged and it's lead was dislodged.
Schematic:
Schematic:
Yeah, the weaker signal on pin 1 is what is throwing me.
But at the same time the rate LED isn't lighting up too.
Likely the two are related.
Ah, forgive me, I had read that backwards. I thought you had said that you had a weaker signal at 2, not 1.
I would check voltage at pin 8 of the op amp. I see that there is an LED on the bottom of that socket.
What did you do to make the rate LED switchable? Looks to me like the trick there would be to connect the anode of LED2 to the same point as where R102 meets the switch.
