I had this working just fine but needed to put it in a different enclosure.
After removing it and hooking up power the Rate LED does not receive power and there is virtually no output.
Using a audio probe, on IC1, pin 2 I am getting a good strong signal. On pin 1 of IC1, the output is half of the signal going to pin 2.
Is this lower output on pin 1 expected or might there be another issue causing this?
