Mahayana IC
huntest
The more I read about an IC for my Mahayana build, the more confused I get.
There seems to be a number of substitutes for the AD712 IC and since I will be using a socket I can try different options. I've looked at Digikey and Mouser and I can't decide which to try. Suggestions and advice please.
Also would appreciate suggestions and advice on which transistors to use.
Thanks a bunch
This is what I typically put in them.. Kinda spendy .. Plain ole TL072 works fine too
Thanks
I'm going to go with the OPA 2134. I'll use a socket so I can have some flexibility.
Always go with the sockets in the case of ICs. Nobody needs the stress desoldering an IC.
The OPA2134 is maybe a bit overkill in an overdrive, but at that time the Hermida was developed they still were affordable.
Even if I tried to straighten the legs, the chip is surely damaged 😞
TL072
LF353
NE5532
LM1458
4558
literally any dual opamp will work. (personally i wouldn't bother with the OPA2134 for a drive circuit)
as mentioned above, if you use an 8-pin IC socket (or build the circuit on a breadboard) you can then audition any one of these opamps to determine which you like the sound of the most.
build doc specifies 2N7000:
tayda has them.
also:
I finished my Mahayana pedal and it sounds great BUT the noise floor is a bit excessive. I've read where this circuit is prone to this.
Do you have any suggestions for fixes or know what the source is?
Thanks
Thanks
Congrats on getting it done! The Zen drive is one of the lowest parts count builds out there.
But at its heart it's still a Tubescreamer, albeit with a variation on the clipping. There's not much you can do about the noise floor. It's inherent in the circuit. Some overdrives are just like that. The Boss SD-1 is another. One of my favorite OD's but noisy.
