joelorigo Well-known member Yesterday at 1:39 PM #1 The build doc has notes about the parameters for the transistors. Are the 2N5457 ones sold at PedalPCB fit those parameters? And D1 & D2 are BAT43 which Tayda is currently out of. Are there other diodes that would be an acceptable substitute?
Feral Feline Well-known member Today at 2:44 AM #2 I can always use more 2N5457, so I'd just get the PPCB ones and try them out, measure them and use the ones that most closely match the parameters set in the build doc. Have you got any Bat42? https://modwiggler.com/forum/viewtopic.php?t=256127
zeropluszero Active member Today at 3:27 AM #3 I had the exact same question trying to build the Median as well. i got some bat42, 41, 46, but no bat43
R rossbalch Active member Today at 5:43 AM #4 Almost any BAT diode will do the job. The BAT56 is a bit lower than the other common ones. Last edited: Today at 10:12 PM
darwin999 Well-known member Today at 7:01 PM #5 Digikey has BAT43 for $0.14/ea or 10/$0.98 https://www.digikey.com/en/products/detail/stmicroelectronics/BAT43/603517 And Mouser also carries them.
