Mini Heterodyne Receiver Volume
phi1
From what I can tell, the only difference feature wise between the Mini and full size Heterodyne Receiver is that the Mini doesn't have a master volume. Do people consider this a problem? I generally like the option of running my pedals at unity volume, so if the Mini is much louder with no way to control it, maybe I should just build the full size.
Of course I could add a simple volume control on the output, but I imagine it's pretty crowded in there. If you were to leave out one switch or pot control and put a master volume in that area, which control would you leave out?
You can control the volume of each voice individually. So while you don't have a single "Master" volume, you still have full control over the volume.
You might want to try A100K pots (instead of B100K) for the SUB, OSC, and SQUARE pots just so you have a little better control over the lower volume settings.
