Mini KoT no LED
Jbanks
I’ve finished the mini KoT and it sounds great but I can’t get the right LED to work. I’ve pulled it out of the enclosure and am testing just the board plugged in. Replaced the LED and no luck. The 4k7 LDR seems to look fine. Any thoughts on what gives?
Thanks in advance!
James
Check continuity
Ok. I’ll try replacing
Or maybe just check continuity like PJS suggested...
Jumping to replacement without verification of a failure is as likely to cause problems as solve them.
If you're not familiar with how to do that, this would be a good place to ask/ search for a post that explains the process.
Very good point. Ok, how do I check continuity between the 3pdt and the LED? I’m assuming one point goes to the anode (+) side of the LED lug and one goes to a 3pdt lug? It looks like LUG 3 on a 3pdt is usually the LED signal? I’m using a PedalPCB daughter board too.
Thanks
James
Check continuity on the switch. It doesn't really take all that much heat to damage a stomp switch
