Paul.Ruby
Any interest here in a mini-pedal DIY platform? I found an existing mini-pedal that is already a decent DIY platform, using two PCBs. It has a bottom board with I/O jacks, true-bypass footswitch, 9V and Vref supply, LED support, and an emitter-follower buffer on the input signal prior to sending up to the top board. The top board is for the custom stuff. I've done a handful of builds making a top board by hand on generic through-hole boards (plexi drive, POT, Dynamic, OCD). Just wondering if there is interest in a generic mini-pedal base platform and if PedalPCB could/would make such a thing. The downside of the pre-existing mini-pedal is that the top is already drilled for exactly 3 pots (alpha 9mm) and, for the life of me, I cannot find a tiny toggle switch (existing pedal has no toggle switch) that would fit in the same clearance (~7mm) from the chassis to the PCB. I have lots of pictures if there is interest.
