andare
I just finished building a Minnow. Definitely the most complex out of all the 8 pedals I've built so far but it worked right away. Everything seems to work as intended but I have 4 issues, 1 of which I've been able to solve:
Here are pics of my low-rent build:
Thanks in advance for any help you can provide and I hope this post is helpful for future builds.
- Whistling on bypass. This is due to IC2 being close to the output tip wire. Keeping this wire on the other side of the enclosure greatly reduced the whistle. I used shielded wire but I grounded the jack with a regular wire to the PCB. I suppose that defeats the purpose? Anyway I built a shield for IC2 using electrical tape and adhesive copper tape and grounded it to the output jack sleeve. Thanks to @Kinski for the idea! The whistle is gone.
- Ticking on bypass when S/H mode is selected. This is caused by the always-on Speed LED. I don't know how to mod the pedal so the LED is turned off on bypass. The Speed knob is enough visual feedback for me. Is there a way to short the LED or should I just cut off one leg to disconnect it?
- The pedal is well below unity volume in both modes.
- The Filter mode has low sensitivity, I really have to dig in to get the filter to react. Might be connected to #3.
S/H mode works fine (Ship Ahoy!) though I might fine tune the trimpots once more.
