vigilante398
Authorized Vendor
Matchless has always been one of my favorite brands out there, so I guess it was only a matter of time before I got to this one. The Matchless Vibrobox is an all-tube tremolo/clean preamp with a vaguely Vox-ish flavor. Mirage Tremolo takes the Matchless circuit into a 1590BB enclosure, getting rid of the power transformer for an SMPS per my usual style.
The original acts as an always-on preamp with the tremolo section activated by footswitch. I've designed this to be operated either like the original or as a true bypass tremolo.
It's a pretty straightforward build if you've done any of the C2C builds before, no super weird components, or at least nothing weirder than in any of my other builds.
Anyway, check it out.
c2celectronics.com
Mirage Tremolo PCB Set
This is a PCB set for building your own Mirage Tremolo. This is not a beginner project, so if you’ve never built a pedal before, then this isn’t for you. I’ve tried to make this as affordable and a…
