Robert
Reverse Engineer
Hey, I’m in search of the build documents for the Liquid Crystal Fuzz.
Thanks in advance
It's identical to the "Chelsea" variant in the Muffin build docs:
Thanks in advance
About the Acrobat -> bumpYes, of course. I've been away from my bench for a few days so I have some catching up to do, but I'll get it posted for you.
Reference the device datasheet.Same subject but different request: would love just a drill template for the MicroXLR. I’m never too worried about drilling Pots and what not and most of the time the dimensions are similar from pedal to pedal. This XLR gives me anxiety because of the two mounting screws and I’d like to modify some existing pedals so fubar’ing a perfectly good enclosure is another layer of anxiety.
Thanks!
Sounds like a great way for me to fubar a perfectly good enclosure. It’s why I made a request.Reference the device datasheet.
Oh man you’re right what was I thinking.Sounds like a great way for me to fubar a perfectly good enclosure. It’s why I made a request.
Yes, I’m aware that it could change depending on the jack used but in my parts I have 2 other panel mount XLR jacks, that aren’t solder lugs. Besides the part you specified neither fit the footprint of the board. Begs the question of why would anyone use a different jack.Try this, double check it before drilling.
@benny_profane is correct though, the drill template could vary depending on the XLR jack used. The attached template is for the XLR jack from Tayda, if you use a different jack you'll need to adjust the coordinates according to the datasheet.
Here's the parts list:Hi, any docs coming for the Silica fuzz? / ETA? thank you!
Yup - hidden in Robert’s secret schematic drawer - there must be some issues with it being public, I imagine Mr Reed - Smith is the litigious type !!!Heya everyone, I am desperately looking for the schematic of the Mystery Meat Overdrive, is it available somewhere?
Are there any plans to do this in a through-hole circuit board?I'll get everything posted ASAP. Here's the values for the MicroBlend (since they aren't printed on the PCB on this one).
This is the XLR jack I used:
