Missing Build Docs / Schematics
SCABBARD
4 100R
1 1K
2 2K2
1 4K7
3 10K
1 20K
3 47K
3 1M
3 1n
1 3n3
2 10n
3 47n
3 1u MLCC
* Filtering/decoupling, use MLCC
11uF E
4 4u7
2 100u
2 D9B
1 5817
4 A100K
2 OP07
1 8.2uH
* https://www.taydaelectronics.com/8-2uh-inductor-ec24.html
1 ON/ON
I have the drill coordinates for tayda if you want them.
I'd like those coords, if you please. Scabbard is a definite future build from me! I'd love to see the schem for it too whenever that drops.
Hi @Robert. Any chance of a drill temp for the 4 tap DC convertir/isolator. And the length of the standoffs requires. Thanks.
Definitely curious about the sizing for the standoffs. Already drilled the enclosure and the board is pretty snug, but would like to figure out what size screw/standoff/ mounting hardware fits those holes
A couple of Tayda drill template questions:
I assume the Antithesis is just the basic 4 knob layout, so pre-drilled boxes would work? Similarly Bellum Fuzz MK. II is a 3 knob.
But how about the Abyss? It doesn't seem to be the normal 5 knob layout, are there measurements somewhere or a Tayda drill template? I didn't find any. I can always measure the PCB but I don't trust myself to get it 100% right. Better than nothing else if it comes to that.
Similar question for the Fuzz Cadet, I do have a drill template for the Simulcast which I think is similar? I think I had some slight issues with the Simulcast when I built it, but nothing I can't fix afterwards, so if there's nothing better I can use that one (assuming the template is similar).
Abyss is 5 knob Type II
Thank you! Excellent!
Edit: Anyone know about the Fuzz Cadet?
Edit2: Right, the Fuzz Cadet has the switch on the opposite side to Simulcast/Danube fuzz, so it definitely won't work with the same template. Anyone have the measurement for how far to the side it is on the Fuzz Cadet or should I measure it myself?
