pingpongcomputer
I deleted the guesswork drill guide I made for the Muffinator. I made everything fit, but several of my "measurements" were off. Figured it was better to take down the post and not lead others astray.
Is this a good template for the Muffinator then?Your template looked correct to me.
Keep in mind the LED almost never aligns with the pads on the PCB with the projects here. That would require either some really wonky LED placement, or severely oversized PCBs just for the sake of LED alignment.
It also allows for the use of the big bulky metal LED bezels that would otherwise short against the back of the PCB.
It looked good so I used it. It worked perfectly. I usually have a hard time with toggle switches lining up right, but this was spot on.Is this a good template for the Muffinator then?
No worries! It came together nicely. Do you have any recommendations for different diodes?Sorry, just saw this.
Yep, that's the one, but you know that by now.![]()
bump...Any chance for the Sandblaster Fuzz schematic?![]()
I'd settle for a yes / no I can buy all its parts from taydaLycan Overdrive build docs?
SCABBARDbump...
Scabbard Overdrive would be nice too![]()
I'd settle for a yes / no I can buy all its parts from tayda![]()
Sandblaster fuzz schematic would be awesome if possible please
Knock, knock...
Thanks for your offer, it won't be necessary. I already have everything I need.I have the drill coordinates for tayda if you want them.
I'd like those coords, if you please. Scabbard is a definite future build from me! I'd love to see the schem for it too whenever that drops.SCABBARD
4 100R
1 1K
2 2K2
1 4K7
3 10K
1 20K
3 47K
3 1M
3 1n
1 3n3
2 10n
3 47n
3 1u MLCC
* Filtering/decoupling, use MLCC
11uF E
4 4u7
2 100u
2 D9B
1 5817
4 A100K
2 OP07
1 8.2uH
* https://www.taydaelectronics.com/8-2uh-inductor-ec24.html
1 ON/ON
Thank you very much, I appreciate it. I'd like to get one printed and drilled when I get around to that project so this is very helpful.Scabbard (rev 1?)
Obviously check the diameter of your holes, but my PCB has dropped right into this.
