I think this should work:Synopsis Overdrive drill guide? Please and thank you
No Chance?Hi @Robert
any chance to get the schematics for the Drebbel Bass Preamp? Looking forward to building it...
No Chance?
The Muffinator Fuzz is identical to the PedalPCB Muffin Fuzz, with the addition of switchable diodes in each clipping stage. Build documentation for the Muffin Fuzz is here... Download Build DocumentationI sat down to build my new Muffinator, and saw that it doesn't have the part values on the silkscreen, and the build docs are still coming soon. Any chance there might be a parts list floating around?
I did my best to search, so I apologize if I missed it.
Thanks!
Awesome, thank you!The Muffinator Fuzz is identical to the PedalPCB Muffin Fuzz, with the addition of switchable diodes in each clipping stage. Build documentation for the Muffin Fuzz is here... Download Build Documentation
Also awesome, thank you!EDIT: What he said.
The BOM is identical to the standard Muffin with the exception of the two added toggle switches and extra diode pairs.
D3/D4 (UP) and D5/D6 (DOWN) are the clipping diodes for the first clipping stage
D1/D2 (UP) and D7/D8 (DOWN) are the clipping diodes for the second clipping stage.
The two toggle switches are SPDT ON/OFF/ON, unless you don't want a "no clipping" option in the center position. In that case, ON/ON.
Will there be a drill template for the Muffinator? Or Is there something that has the same layout?EDIT: What he said.
Is there a drill pattern for the Lerxt (Chili Dog) yet?
Bump. Curious, any update on this?I'm working on the doc for both of these today.
Could I get a BOM for the Speaker Motivator? Just want to make sure I have the right pots and transistor on hand.
Thank you sir!
what 24LC32A is compatible. I have 2 custom ones (both with 8 effects) I have had made and and extra specialist because I apparently can't read right. Any of those work? I have blanks and a programmer too. Right now it's the only thing missing to make it workI'll get it posted ASAP. Is there anything specific you need to get you started?
