Tip and sleeve connections on both jacks wired backwards. The effect worked but sounded awful. I looked over the board itself so many times before checking the jack wiring
I spent probably a solid half hour troubleshooting why I got no output only to realize my volume pot was turned all the way down!!!
The one I do a lot is test without fitting op amps in sockets. Also getting plugging the cables in the wrong way and struggling because it works in bypass
These are the most usual ones, that I do almost every builds. Once, I even started a thread on diystompboxes because I left the volume pot turned off. I had to face the other members and tell the painfull truth... I'd say these omissions are coming from our enthousiasm, rushing things to complete and enjoy some new effect.
I hate it when you spend all day working on a pedal...testing components, selecting transistors, drilling the enclosure, adding artwork, soldering, wire up, etc...only to plug it in and nothing...because its actually a sandwich.
This one I would be proud to experience it, that would mean that i finally accessed a whole new level.
My last build is a Moosapotamus classic 360 bass fuzz on perfboard, squeezed in a little box type B.
First try, some things worked, I didn't know exactly what to expect from the circuit because I had to make some questionable substitions on 2 transistors, demo on youtube gave me a general idea, that's all.
2 controls weren't working so I knew something was wrong. I spent 4 or 5 hours checking my soldering, isolating pots, hunting for shorts. I tried many transistors, tried the famous desperate magic trick (touching the soldering side with fingers), took some voltage readings and finally realized the circuit layout wasn't complete on my board.
I had a moment of self-questioning : "When will this end ? do i give up, even after all this ?". The layout was simple enough but I doubted that I would be able to find the missing connections on my board, which was already a dense jungle of links. I didn't even know how much was missing...
I managed to go to bed and find the links quickly the next day. My meter told me a transistor wasn't getting any current, that's how I found it.
It still didn't work properly though, because of a single little thread from a wire, that didn't go through the hole, and was shorting with a component close to it...took me only another 10-15 minutes to spot it. Pure luck obviously.
You can have a look on the build, reply #29636 :
Pictures! - Page 1482
www.diystompboxes.com
