Bigshredder
Hi,
I just finished my triple pedal
Triangulum boost -> hm-2 -> muzzle. Everything works but the gate creates a whistle sound when engage. And it’s crackling a lot when I am not playing. When the muzzle is not engaged it sounds awesome. And the the muzzle is on and set low so that the gate is open all is good. But when it kicks in it whistles. I have heard that 2 charge pumps in the same pedal can caus this problem. I have 2 questions on going forward with this build.
First, can I bypass the switch jack? I don’t need it and I suspect it might cause problems. The middle wire of the switch jack (green and is not connected) on my other muzzle I built 2 years ago I have connected to ground. But when I try to connect it it does nothing. The building docs doesn’t show the middle wire.
second, it the whistle sound comes from the 2 charge pumps, can I change the one in the muzzle or take it out?
