Hi DIYers, this is the first time I post here but I've been reading this forum for a while.
I actually have a question about the Muzzle.
Everything seems to be working properly :
- in front of the amp => OK
- in the effect loop without using the key jacks => OK
- in the effect loop with key detection using a splitter => OK
- with the 4 cables method => OK
Led is working as it should, blue when gate is opened and blue & red when closed.
BUT here is my problem : with the 4 cables method (the best way to use this pedal) and only when I engage a boost between the passthrough and the amp, a nasty squeal occurs passed an amount of boost.
This squeal disappears when the Muzzle is in bypass or when I use a splitter to feed the key and nothing out of the passthrough.
I tried with other boost pedals and it's the same thing.
Do you have an idea to solve this problem ?
Thx
Thx
