That second jack is a no-no for center negative. Potential to link your barrel to the ground plane.I use this one from Tayda. I only have problems if I leave the solder iron on a tab too long. It will melt!
I had a lot of trouble with this Jack, so I avoid it. I wonder if it is the same one causing your problems.
Thank you I am looking for the other plug side like in the picture.I use this one from Tayda. I only have problems if I leave the solder iron on a tab too long. It will melt!
The last time i ordered these the nut was incredibly loose throughout all of the threading to the point i couldn't use 3 of the 5.I use this one from Tayda. I only have problems if I leave the solder iron on a tab too long. It will melt!![]()
stompboxparts.com
