"I was tempted to make the 10K resistor and 100nF cap on the 9V a 1N5817 diode and a 100µF cap but kept it as drawn. I'm not familiar with the circuit."
Oh the 1N5817 is kind of a standard polarity protection diode - Look at the majority of schematics here and you'll see them. It's also quite common to use a small value resistor in series with the diode and I forget why we do that! The other thing which is very common is the filter cap - if in doubt I often use a 100µF cap between the incoming voltage and ground. It's to filter noise from power supplies. Again, you'll see anything from 22µF to 330µF used for this. Look at the schematics on this site. 100nF seems a bit to small to act as a filter cap.Also, what difference would the suggested change make?
Ah ok, but should I keep the 10K resistor in that case or would the diode replace its function (transistor bias?)Oh the 1N5817 is kind of a standard polarity protection diode - Look at the majority of schematics here and you'll see them. It's also quite common to use a small value resistor in series with the diode and I forget why we do that! The other thing which is very common is the filter cap - if in doubt I often use a 100µF cap between the incoming voltage and ground. It's to filter noise from power supplies. Again, you'll see anything from 22µF to 330µF used for this. Look at the schematics on this site. 100nF seems a bit to small to act as a filter cap.
FWIW I sometimes prefer to use a 19-20 row wide board whether the extra width is required or not. It helps to locate the board within the enclosure because it can't rotate as easily to get caught in other things.
And if you're only using two pots - as in this case - I would probably suggest using some of that thick, kinda padded double sided tape to attach to board to the enclosure. It's the sort of tape you use to stick mirrors to walls. It's thick enough to prevent any shorts to the enclosure from the back of the board and easy enough to unstick if you need to.
Why isn't it optimal? (Im trying to learn as much as possible ^_^)The 10K resistor isn't optional. It's part of the transistor stage, not the power supply. (R3 below)
No no, not optional. The circuit won't work without it.
