![IMG_20240215_145954954.jpg IMG_20240215_145954954.jpg](https://forum.pedalpcb.com/data/attachments/68/68580-fa17b64689c4dd90bc2806cf253e8cb9.jpg)
Went to final test my madbean boomboom/brassmaster build last weekend and my bass is suddenly squirrelly. Radio stations always and noise whenever anything grounded is touched.
Signal still present.
It's a modded Ibanez SGR505 or 525, can't remember, with a Dark glass tone capsule preamp swapped in for the cr*p stock preamp(highly recommend).
I reflowed the grounds, no change. I think the preamp electronics are skewing the resistance readings but string to pot is 2 ohms so I think my grounds are good.
I'm thinking the switched barrel jack is borked but figured I'd ask here before dropping money on one. Probably not going to have time to dig into until the weekend though. It seems like the switching is off, getting ~160k between input and ground but again, not sure how much of that is electronics and pickups.
Also. If anyone has a recommendation for a qualiry barrel input jack, I'm all ears. I have a cheap Chinese one I bought as an emergency use only(need it to work now/don't need it to work long) but I'd rather put a quality one in and only do it once.
Good news is it's not the brassmaster.
Thanks guys n gals.
