I studied your resistor values, I believe they are all correct.Tried a different chip (I bought a few). Pin 3 measured 2.22 on that one. In looking at the schematic, if I’m reading it directly Pin 3 is where the input shows up. Maybe I should work backwards from there (if that value is indeed wrong).
It's all Fun, I have to shoot off now but I'm sure you will get it fired up!Thank you, Music, for going to the trouble.
Less fun at the moment.It's all Fun, I have to shoot off now but I'm sure you will get it fired up!
I’m still trying to get better at soldering. The stupid stuff tends to pull up toward iron instead of staying in the holes!!Some of those solder joints look like they could use a reflow, I see a few that look like round blobs they should look like a Hershey kiss or a teepee
The voltages are all good.All those voltages look good except I would expect pin3 to also be close to 4.5v (though I could be wrong). If it’s wrong I’m not sure shat could be causing that. I *think* your switch-diode connections make sense, without having thought too much about it
Are you using 60/40 Flux core Solder. If So, What Brand?I’m still trying to get better at soldering. The stupid stuff tends to pull up toward iron instead of staying in the holes!!
You hurt my meter’s feelings. ?The voltages are all good.
Eric's DVM is loading down the voltage when he measures pin 3. You're using a cheap DVM. It's ok in this case, we can compensate for it, but if you get serious about pedal building, get one that has 10Meg input impedance. Yours is 1Meg.
stompboxparts.com
Is it easier from the printed side or the side where the ends of the wires stick out?Some of those solder joints look like they could use a reflow, I see a few that look like round blobs they should look like a Hershey kiss or a teepee
I got them here....https://www.pedalhackerelectronics.com/Original-Panasonic-MA856-Diode-p/ma856.htmWeird that neither switch does anything...
Where did you get your MA856 diodes? Does your meter have a diode setting? Can you confirm that they measure around 0.5-0.7v across each one from anode to cathode?
Side the wires stick outIs it easier from the printed side or the side where the ends of the wires stick out?
With the switch in the UP position, the Center & Bottom lug should be making contact, Check for Continuity!Probably worth confirming a couple things....this is the toggle switch I got...
DPDT Toggle Switch ON/OFF/ON- Solder Lug- Long Bat
Top Quality Parts for Guitar Effects Pedals and DIY Music Devices. Knobs, Pots, Switches, LEDs, Enclosures, Jacks, Wire, Resistors, Capacitors, Semiconductorsstompboxparts.com
