j_m_earley
Hey all. First time long time. Recently completed the Ocelot Octave, or so I thought. I get signal and a hint of octave from Oct 1, but that's really about it. From what I can tell, the issue is with IC5. I've tried troubleshooting it a million different ways, but nothing has worked. There are no shorts. The other pins are getting power. Swapping in a different IC produces the same result. I've re-soldered the socket. But that pin is causing a cascading effect where none of the other ICs are getting adequate power, so this octave pedal just isn't octave-ing. One thing to note: pin 8 was also not getting power, but a jumper wire from the DC jack addressed that. That's when my pin 1 issue started. It was reading 9.5v before, which is too high, but better than 0v? Any advice would be greatly appreciated!
