Ocelot octave problem
Wildniko
Hello
I already achieved four DIY pedals. Some of them give me hard times but they work very well.
But with Ocelot I do not find the problem. The LED blinking and a little and repetive noise (tac tac tac) comes from the amp… :(
Can anyone help me ?
Nicolas the wild.
Definitely all IC's are installed backwards..... You also have a ton of components that you can visibly see the solder did not wick to front side of board.... Your likely going to have a lot of cold solder joints as well....
In fact I have a ic support that I wicked bad. There is false contact. But I can’t remove it or correct all the wick at the same time.
I can rewick this ic support ?
