Octarock with an oct up switch.
kristopher
3.00 star(s)
If you decide to build the Octarock, with a switch to disengage the upper octave, put it in a tall enclosure. I used a 1590bb. The jacks are as high as possible, and I taped the area where the input/output can rub the Pcb. If the jacks were lower, then the components and switches get rubbed, I think. I had it in and out of the enclosure a dozen times. Most of the holes are bigger to allow some wiggle, and are barely covered by the washers. I messed up on the 9v jack location. I had to notch the back plate. No big deal. I’m happy it all fit.
Also, I had to wait for the LM348 to be delivered. So I tried the circuit without an IC in there. It works, but without the upper octave. I plopped a TL074?? in there and it worked, but not a smooth(?) as the LM348.
The switch mod was recently discussed in this thread: https://forum.pedalpcb.com/threads/octarock-additional-switches.18966/
I used a dpdt foot switch and I’m glad I did. Being able to pop the upper octave out is fantastic. If you have an Octarock, I suggest it. I plan on doing a shootout with the Octron, because I have one. It has a TL084CN in it. I hope an I phone recording will suffice. I’ll get to it tomorrow. So stay tuned.
They both look great dude. Congrats on enduring it to completion. Humans win!
Did you remove the toggle switches' inner nuts and washers? I find that gives some essential extra room.
Looking forward to your phone demos!
Yes. I did remove the toggle switch washers. In both builds.
Having the small 9mm pots helped with space too. Here’s a photo of the board and off-board pots, and the guts.
I’m thinking I may build a third Octarock, because the second wasn’t perfect. Neither was the first. The third bowl of porridge should be just right.
I was over confident when I drilled the enclosure, and I should’ve measured THRICE! There is about four mm’s of wasted space between the pcb, and the upper area of the enclosure. The 3pdt switches could’ve had more room. Anyway. Just a bit of OCD. Obviously I’ll post a third build if I do it.
And I do apologize for not getting a demo posted. Life gets in the way.
Go Humans!
