Overloader! (6 Transistor Big Muff)
Morbidpale
BEHOLD! The OVERLOADER!
Just a big muff that was tweaked and tweaked until it was great. Then I started experimenting with a way to blow it out more effectively than a boost in front. I put a Bass Boost in between clipping stages with a blend. Gain and Overload(Bass Blend) are very interactive with each other. This muff can sound crackly, gated, doomy, broken. It all depends in the positions of those two controls. Led clippers at Q2 are essential to getting enough signal to the overload section, Si essential at Q3 to squash it back down.
The tone stack is almost flat. The button on the side changes the Low Pass side a little and brings back some of the Muff scoop. Its subtle but it works well for me. Using the push button over a toggle seemed like a good idea to keep things looking simple but it was more trouble than it was worth.
The layout is not my favorite but I needed to fit into a 125B. Still, it looks pretty tidy.
Credit where credit is due.
The art is a beer label I peeled off.
Artist: Ibay Arifin Suradi
Brewery: There Does Not Exist
Beer: South of Nelson (Delicious)
I hope some people try it out for themselves. The pedal and the beer. Let me know.
I have a question, in your schematic near the 1n914 diodes you have R16 with a value of R27. Is that supposed to be 27k?
Thanks for catching that error. Its supposed to be 22K.
I fixed it on the schematic so its clear.
Why these particular transistor choices?
5088 is a solid transistor for just about anything and most of us have plenty on hand. I wish I had a technical reason I could give for the bc549c but it really was what sounded best to me. I tried a ton of choices and things worked best when Q2/3 were different from the others. It brought some more flavor to the clipping stages and definitely helped the overload feature work better. Bc549c were the winners after lots of tinkering.
Nice. Thanks. I also noticed at least one of the R numbers being used twice, for instance there are 2 R16. I think there were a few more but can't remember. Working on my first cup of coffee lol.
Interesting. So it didn't sound as good if say all transistors were BC459s in the circuit?
It sounded fine. Its a real hair splitting kinda thing. But if I a/b them it's different enough that prefer it the way it is. You could go all 2n5088,bc549,bc546,2n3904 off the top of my head and sound good.
Which transistors from the BC series would work as alternatives to the 2N5088, because these are much
more expensive than e.g. the BC547C ?
Im not sure what would be a 1:1 equivalent but try what's on hand and see what sounds good. After all ehx famously used what was cheap and available and now we have all the variants we obsess over.
This looks cool as hell. Question, what is the mid shift 1&2 going to? I see you have a coupling there. Is it an inner trim pot? Inner mounted switch?
Wait, I see a momentary switch on the side. I guess I know now. Haha
Good catch. Looks like i forgot to list the switch on the layout.
