Hi all.
I've built the full size Paragon. I was lucky enough to be able to source genuine Panasonic MA856 and Toshiba 1s1588 diodes from European / UK suppliers, and I am absolutely blown away by how the pedal sounds. up to a point.
There's a squeal at the pedal's extreme settings that I can't get rid of, so looking for guidance.
The business diodes are socket mounted, as are resistors R3 (1k) and R17 (100k).
So far, I’ve swapped out the charge pump and both opamps for compatible versions, and shortened the diodes’ legs so that they sit flush berween the socket posts (I initially left them longer than they needed to be).
The squeal persists.
it’s only there when both sides are on and the pots are near maximum all round.
Boards are connected with trimmed header pins and none of the cables to the jacks or 9v are axcessively long. Jack sockets are open Neutrik jobbies.
Pots and 3PDTs are Alpha.
Any ideas on where to go next?
