So.. looking at the order on the pedal it looks like the boost is in front whereas the actual pedal the boost is after the drive?. I may mod for an order switch but im just writing to clarify..
That depends on whether you're looking at the original from above, or with the knobs facing you... Even still it's not a direct comparison since the original controls were in a straight line.
It was never really intended to be cosmetically identical.
