S sean2damax New member May 29, 2020 #1 Which germanium diodes specifically do you guys suggest placing in D2 and D3 on the Parentheses Mini Fuzz?
Nostradoomus Well-known member May 29, 2020 #2 Most will work fine as long as they are matched for Vf. I used 1n5817s in a few of mine and it sounds great.
S sean2damax New member May 29, 2020 #3 Nostradoomus said: Most will work fine as long as they are matched for Vf. I used 1n5817s in a few of mine and it sounds great. Click to expand... Thanks! Do I need to buy those matched or can I test them with a multimeter?
Nostradoomus Well-known member Nov 24, 2020 #7 wui223 said: Is 1N5817 a schottky diode? Click to expand... Yep
F falzhobel Active member Nov 25, 2020 #8 Always been using D9K and they are great. The "false" Tayda 1N34A work also. Just be sure to match them as said before.
