Parenthesis Fuzz Expression Jack Mod Issue
So I wanted to add a jack for an expression pedal like EQD has on the new ones. I found something online as to how everything should be hooked up. The distortion and boost worked as should but when I turned on the octave it lowered the output, and after I plugged a stereo cable in, it didn't work, and once I removed the cable it just hums like it's going to ground when I switch on the octave.
It's hard to tell from the photo where the wires are going.
Can you post a pic with the jack removed from the enclosure so the wires are more visible?
Yes, 2023, May. Doing the same. Located (pictures inside pedal). Any news on your update? Thank you.
