K Pedals Well-known member Jul 29, 2019 #1 Just got this done and it’s working good but when it’s bypassed there’s a high pitched whine???? Any ideas??
K Pedals Well-known member Jul 29, 2019 #2 And when I move the knobs in the distortion section it affects it in bypass...
K Pedals Well-known member Jul 29, 2019 #4 I figured it out... the jumper from lug 1 and lug 7 on the 3rd footswitch is missing from the wiring diagram...
Fuzzonaut Well-known member Jul 31, 2019 #5 K Pedals said: I figured it out... the jumper from lug 1 and lug 7 on the 3rd footswitch is missing from the wiring diagram... Click to expand... Thanks for pointing this out, but shouldn't the missing jumper go from lug 1 to lug 6 ... ? Like this: Just visually double checking to make sure. I get easily confused with footswitch wiring ...
chongmagic Well-known member Jul 31, 2019 #6 Fuzzonaut said: Thanks for pointing this out, but shouldn't the missing jumper go from lug 1 to lug 6 ... ? Like this: View attachment 965 Just visually double checking to make sure. I get easily confused with footswitch wiring ... Click to expand... I believe K Pedals meant 6, yes 1 to 6 would be correct.
K Pedals Well-known member Jul 31, 2019 #7 Fuzzonaut said: Thanks for pointing this out, but shouldn't the missing jumper go from lug 1 to lug 6 ... ? Like this: View attachment 965 Just visually double checking to make sure. I get easily confused with footswitch wiring ... Click to expand... Yeah that’s right...
Robert Reverse Engineer Aug 4, 2019 #10 Allthumbs said: Can 3DPT boards be used on all 3 foot switches? Click to expand... The Octave switch isn't a straight pin-for-pin match for the 3PDT board, but you should still be able to use it. I'll look at the pinouts in the morning and post a diagram.
A Allthumbs Active member Aug 5, 2019 #11 Robert said: The Octave switch isn't a straight pin-for-pin match for the 3PDT board, but you should still be able to use it. I'll look at the pinouts in the morning and post a diagram. Click to expand... I'm sure I can figure it out based on what you have. if I get stuck I'll ask . thanks much
