PedalPCB Acid Rain Fuzz
fig
Village Idiot
I had posted pictures of a couple of builds on another thread, but a few folks pointed out to me they really belong here :)
This is an original BuggFX design, and in my opinion, this is how an Si fuzz pedal should sound. The Baxandall TS gives you great leverage to play through chords or saw through the single notes all over the fretboard.
If fuzz is in your future, you should build this pedal.
Oh that? That's a "harness thing". :ROFLMAO:
It's a couple of pogo pin test clips and the PedalPCB mini protoboard. It's just a way to test the board prior to soldering wires.
Here's how they work....warning watching loop too long may result in "spring fever" o_O
How do you even come up with this stuff?!? Very very clever! I usually rock it after boxing it although a recent experience has made me reconsider that approach and now my OCD brain wants this same harness thing.
Musikding sent me this PCB by mistake when I ordered the Photon Vibe, so it's lying around.
Fig, why do you never use ceramic caps? I assume those yellow bulbs are tantalums
Reactions: fig
I think Fig is like me...he likes using tantalums in place of electrolytic. I've started doing this myself. Unless it's specifically called for, I use tantalums. Mainly because they take up less space but also because they last longer and have the potential for less noise.
Well, yeah....what he said.;)
I read that tantalums are noisy in the signal path and can explode
Pedals generally aren't subjected to the stresses and strains that plague capacitors in something like a Hifi Amp. High voltage, heat, longer power cycles, vent exposures, circuit size... Pedals are very low impact devices to their components. In a standard pedal, you really shouldn't be seeing any capacitor failure or noticeable audio differences between different capacitor types unless they are installed wrong or overrated for voltage.
I bought them at theBay...I'll send you both (and anyone who wants it) the seller link. You can configure them with however many pins/rows you like...They come with the clip and the jumper wires.
Me too!
Reactions: fig
