Brett
- Build Rating
- 5.00 star(s)
Build went together very smoothly thanks to the wonderful layout and spacious PCB.
I typically stick to Tayda's UV printing service, but decided to try @amplifyfun for a laser-engraved faceplate on this one and I'm very happy that I did. Spencer was wonderful to work with and delivered ahead of schedule.
If I were to build this one again, I'd probably make a couple minor adjustment to the drill template. The drill template (provided by @Robert here in the forums) is a little snug with the foot switch pressing firmly against the PCB. I'd move the foot switch hole away from the PCB a couple millimeters and move the LED drill hole towards the controls about 1mm. None of these are dealbreakers and the board still went together perfectly.
I haven't had a ton of time with the pedal yet, but so far, this one definitely shines in subtlety. I think @Dan0h mentioned in his build report that this was a pedal that "you don't really know it's on until you turn it off" and I concur. I'll have to spend a little more time with this one before deciding if the huge footprint on the pedalboard is justified. I may just end up hanging onto this one for when I get my home recording setup back up and running.
Thanks for a great PCB @Robert!
