Thanks,Nice… how do you do the artwork ?
Thanks Michael,@Manuel Ammon Astounding and beautiful work as always. Very interesting relic job!
What diodes did you end up using? They look like 1N4148's?
Thanks for the information. Helps slot to understand the circuit of a Kot....I like my Pauper a lot, but wind up using my KOT more. I settled on using BA282's in my Pauper build which sounds different than MA858's to me. I also have a bunch of BAS33 diodes which to me sound more like the MA858/856. I used those in another KOT clone build. You might also like the King's Hand PCB (It's the MBB side of the Duellist). To me the pedal sounds like a "girthier" version of the POT. Very cool pedal as well.
I realize this is several years old and I don’t know if I can reply to it, but I have questions on your Avery self adhesive printing. I do the same with Avery products either on a white backing or transparent. 2 questions. With the transparent I can not get it totally to disappear. Does the foil backing solve that or is it by printing over the entire piece of label. I.E. essentially adding the background to the label? Second. I had to spray a clear poly coating over everything for durability. Do you do any thing like that?Thanks,
Photoshop, Avery 2500 self-adhesive clear foil top, mirrow foil base, Canon TS 8150 inkjet printer and a lot of time....
