Assuming that leg 1 of the pot is ground, then I think it's correct, but again a schematic would be helpful.Is the Electrolytic facing the wrong way on the Left side coming of leg 1 of the Top Left B50K Pot?
Is the Electrolytic facing the wrong way on Leg 1 of the Top Left B50K Pot?Morning. I breadboarded and then built this point to point pedal. I’m only getting bypass at this point. Any ideas?
Thanks in advance!
The Pot is coming off the Input from the footswitch I think???, this is more fun than a PCB!Assuming that leg 1 of the pot is ground, then I think it's correct, but again a schematic would be helpful.
Exactly why I asked about the foot switch wiring. I can't tell, but I think that when you engage the foot switch, you're dumping the signal to ground???The Pot is coming off the Input from the footswitch I think???, this is more fun than a PCB!
Yeah, that's my guess. It looks like a silicone fuzz with a tone stack.I believe the Top Right Pot under the Output jack is Volume, Leg 1 is going to Ground, Leg 2 is going to Output on the bottom right of Footswitch, Leg 3 is going to 10nf Yellow Cap to Leg 3 of the 1K Gain pot ??? so we are talking Fuzz circuit???
Yes. My take on the Fulltone 69 with an added bias control.I believe the Top Right Pot under the Output jack is Volume, Leg 1 is going to Ground, Leg 2 is going to Output on the bottom right of Footswitch, Leg 3 is going to 10nf Yellow Cap to Leg 3 of the 1K Gain pot ??? so we are talking Fuzz circuit???
I also noticed that my Q2 was in backwards. Fixed that but still no effect signal.I really appreciate you guys taking your time to help me out with this. Attached you will find the schematic and the transistors that I used are NOS Fairchild, 2N2926 NPN silicon. Thanks again.
I checked and I think it’s correct. E of Q1 goes to ground. B goes to C2 and 100k and C goes to B or Q2 and 33k. Here’s a more clear pic. I did switch Q2 around earlier though.Based on the data sheet I'm looking at, it looks like Q1 is in backwards.
EDIT: With the flat side facing toward you the pins from left to right should be ECB.
Yeah, that should be correct.I checked and I think it’s correct. E of Q1 goes to ground. B goes to C2 and 100k and C goes to B or Q2 and 33k. Here’s a more clear pic. I did switch Q2 around earlier though.
Yeah, that means your input is shorting to ground. And I'm all kinds of confused about the way you have the foot switched wired now. I had just wrapped my mind around how you had it wired before. I'm going to have to study this for a minute...I’m also getting continuity between pin 2 of the 50kb and ground. No idea where that’s coming from. Changed the 3PDT wiring a bit too. Here’s a pic.
