I have put together a new BE board and it is not working for me. With a 9v supply that runs the other sushibox pedals with no issues, I am only getting about 113 volts on each tube socket. Cleaned the board with IPA and I have confirmed all part values and connections between the components on the power schematic and the audio schematic. Also replaced the mosfet and the 2n3904. Also switched out the two resistors that set the middle leg of the transistor for a 5K trim pot that is similar to the layout for the standalone power PCB. With that in place I can dial in the power for the tubes at 130v.
I know I am missing something here, because the incoming 9v power is dropping to 4.5v when it is plugged in to the board, and that seems to account for why the voltages at the tubes are only half of what they should be. But I don't know what is causing that voltage drop for the incoming power.
