Danbieranowski
I've put together this kind of overly-ambitious build for my experience level, which is 3 "pedals" in one enclosure with individual outs and a summed out (it's an input into a Zapper which splits to a Rat and a Muff, so a single input, a Rat out, a Muff out, and a summed out of the Rat and Muff). All 3 pedals work, and the individual outs as well as the summed out work. The problem is there's feedback occurring within the circuit. The only time it doesn't occur is via the summed out with all 3 pedals active or if I turn the volume knobs on the Rat and Muff super low.
You can hear the circuit in the video below (which sounds awesome and thiccccc), and you can hear the feedback in the last 10 seconds of the video:
I used @Ratimus suggestion for simple wiring via resistors (47k - see below) to isolate the Rat out and Muff out from the summed out so that I don't get the same signal on all 3 outputs, and this does work... I don't get much Muff bleed into the Rat out or much Rat bleed into the Muff out. The problem is if I push volume above say 10% on either the Rat or Muff I get feedback on the individual outputs (Rat out and Muff out). I don't get this loop on the summed output if all 3 pedals are active or inactive though.
Anyone have any ideas?
This is the wiring diagram I went with that Mr. Ratimus drew up.
