Hey Everyone,
I have build a few Pro-10 dual overdrives before that were successful. This time, I build the pro-10 green and everything turns on and volume and gain work fine, but the sound is very muddy. I figured that there is an issue with a filtering capacitor, or I used the wrong value capacitor somewhere. I also built another Pro-10 dual overdrive and it has the same issue as the standalone Pro-10 Green overdrive.
Things I did so far.
1. Tested the resistors to see if they were the correct value,
2. Swapped out the OP amps and checked the voltages.
3. Checked the transistors to see if power was going to them.
I will
I will
