Yroc006
I have a great signal all the way through until I hit the Q4 2N3904. Then is just fizzles out into a crackly mess. I'm not entirely sure what would be causing the issue unless it's voltages (maybe)? I'm getting 4.3v at the (2) Base (which appears to be in line with the Vrefs), 5.38v at the (1) Emitter and 9.23v at the (3) Collector (which i'm assuming is correct since it's getting power straight to it from the VCC in the schematic). The signal is totally fine though C21 and R21, I can hear it hitting the Base of Q4 at a good volume, but poops at the Emitter. Any ideas? I could potentially just go out straight from the volume pot and be done with it as I've read the buffer stage isn't really needed but I'd rather try to figure this out first. Any thoughts would be appreciated.
