Pyromania
Chuck D. Bones
Circuit Wizard
Thorpy FX Fallout Cloud aka Pryocumulus. It's basically a triangle Big Muff with Baxandall tone controls. What a fantastic sound! It's in need of some decoration and labels, but I'm having too much fun playing thru it right now. Marshall knobs and case from Tayda, gold stomp switch & nut from BLMS, intense yellow LED from EG. Highly recommended.
Annoyingly there's no schematic for it. Cool looking thing though. Isn't it a 4 knobber? What does the 5th pot do?
What? You mean other Fallout Clouds only have 4 knobs?
The Fallout Cloud's first three stages are identical to the Triangle in the Muffin Fuzz build docs, except the 50nF caps are replaced with the easier-to-get 47nF caps and the transistors are BC549C. The last stage is altered to support the Baxandall tone controls.
How does it compare to the Blackout Musket?
Does not have the up-front boost stage of the Musket, but does have a version of the Musket's FOCUS knob (that's the 5th pot). I traced the schematic
from the board, then added a few features.
2nd-stage diode switch: Si - none - MOSFET
3rd-stage diode switch: Si - none - LEDs
With the switches down (Si) and the CONTOUR knob at zero, it's a stock Fallout Cloud. Turning CONTOUR up reduces bass going into the 1st stage.
The Baxandall tone controls work great, completely different from the standard BMP tone control.
" I traced the schematic from the board, then added a few features "....always a CDB Style !
Ive been studying it like always....would using different color LEDS change the tone ?
You put the caps on the one pot....? for us newbies
Anyways , Awesome build, i like that Tayda orange color enclosure...it hides the P-Touch labels very well..makes them blend in
Mike
Mike,
I wanted to experiment with a BMP that had better tone controls and the Pyrocumulus was a perfect platform for that. Changing the diodes was an obvious choice. I tried Schottkys, but they didn't sound much different from the 1N4148s. I also tried varying the bias on the 2nd stage, but it didn't do anything useful IMHO.
LEDs vs the 1N4148 silicon diodes makes a significant difference in the sound. Less compression, fatter midrange. I didn't try different colors. My expectation is that there would be a volume change and not much of a tonal change going from red to green or blue.
I mounted the 2 capacitors on the pot because it was easy to do. They are supported by their leads. It's hard to see, but there is clear heatshrink covering the joint where the capacitors are soldered to one of the yellow wires and a larger piece of heatshrink tying the two yellow wires together. I could have put the caps on the vero board, but decided to go this way instead.
Mike,
Gotcha !
You told me to use the Green LEDS in that LGSM and it made it very creamy ..very smooth. My last LGSM i used the reg diodes off the build sheet...but I'm going to most likely replace them with maybe a diffrent color LED...
Just wondering if maybe using a Green,Yellow, Blue, White LED make the Fuzz types a little more smoother like in the Mod you done, i did notice a difference from the Red to Green in the LGSM..i socketed those and experimented...Green won hands down
It's possible there would be a tonal difference with different LEDs on the Pyro, I didn't try it. The distortion stages don't have a huge amount of headroom and if the LED voltage gets too large, the transistor saturates, giving a completely different sound. That's what happens when I put the toggle switches in the middle position. There are Muff-type circuits, like the Raincoat, that have no diodes and use transistor saturation to make distortion.
FYI, green & yellow LEDs have pretty much the same Vf, so they will sound the same. White LEDs are made from blue LEDs, so their Vf is the same. Red LEDs have the lowest Vf of the visible LEDs and IR LEDs have even lower Vf.
Oh just like green M&M's..lol
Yea i had a chart that showed all that stuff of the LED's.....just can't find it at the moment
Just discussing this the other day. Here is a chart I found online, pretty consistent with what I’ve seen in the past.
Here's a better chart. Vf depends on If. LEDs use for clipping are run over a range of currents. The peak LED current in my Pyro is under 0.5mA. Same goes for the LGSM. At 0.5mA, Vf is 1.62V for red, 1.78V for green. Hard clippers, like the Angry Charlie can get up to about 4mA thru the LEDs.
