Raincoat No signal LED works
Plaidesaurus
Built 2 Raincoats and having the same issue with both, which leads me to think I must have put some components in the wrong place. I've built several of these before to give to other players so not sure what's up. I've tried different sets of transistors on both. They all checked out as working on my meter. Even tried some 2n3904s but no luck. Clean signal works fine, LED lights up when engaged, but no sound from either when engaged. Have looked over multiple times but...
FYI, the unboxed board did have transistors in place and was mounted in a box when I demoed. I'm hoping someone sees something here I've overlooked. THX
What swelchy was saying is you would need rotate the 3904s 180 degrees.
Also, make sure you aren't plugging into the out jack. Easy to do when the pedal is inverted.
Yeah, I actually tried that with the pinout on the 3904s correctly placed just a bit ago. No luck. Can't help but think I've put in some wrong value components. Going to remove a couple of those 470Ps and make sure they read correctly.
I use a test box to drop the finished boards into to test so the enclosure is always as it would be on a pedalboard. Still, I have made that mistake in the past. Thx
