Relay Bypass Module help
Rellømt
Hey,
Im gonna build the Octagon multifx with the relay bypass. So my quation is, or the (input jack and output jack) going into the octagon pcb or the relay pcb?
cheers "the noob"
I'll try to get a wiring diagram drawn up for this... but in the meantime.
Input and Output jacks connect to the relay bypass module, then the four IN/GND/SW/OUT pads connect directly to the Octagon PCB.
He made it so that the relay bypass board can connect directly to the circuit pcb with pin headers. This way the wirings nice and tidy and you’re relay bypass board is supported (not floating around in the pedal).
