The mini is still "in development" and I don't get the impression it'll be available soon. The current rev 3 is the best option.Full size or mini, which rev if full size?
It would probably be the 1590BB2 to account for the transformer height.The link didn't work. If you can just tell me what enclosure you want it in, I can transpose my measurements.
Sorry about that, I went back and double checked my measurements, the switch hole is in the correct X,Y position, the pot holes got shifted up when I read my caliper wrong. I've updated the template and if you would like, I'll reimburse you for the box cost.Finally got around to test fitting the box today, and it doesn't fit. The problem is the switch, hole 7. It's about 3.5mm too far to the south. X position should be 9.5, not 6 mm. Everything else fits, though the footswitches are very close to the wall.
I ain't going to spend the money on a replacement box, so I've bent the prongs on the pots so they reach. I thought about trying to drill the hole out higher but it wouldn't work, not enough room, I'd end up with a very wonky oval hole that doesn't grip the switch properly.
Nah, no harm done. Bent those pot prongs, they reach the PCB well enough to solder in and it won't be a problem. I did wonder if the pot holes were too high on the box, but I've fit-tested everything and there's plenty of room for the enclosed jacks I prefer, so it'll all be fine.Sorry about that, I went back and double checked my measurements, the switch hole is in the correct X,Y position, the pot holes got shifted up when I read my caliper wrong. I've updated the template and if you would like, I'll reimburse you for the box cost.
