REQUEST Revision Overdrive
It appears so. I haven’t printed it out to do an overlay or used a set of calipers on it but it looks identical to all the other 4-knob pedals. There’s no way that one could be different. I use the same printed templates for mine. The Mahayana, Son Of Ben, and Solenoid are all 4-knob layout pedals that I have built using the exact same piece of paper for the template. There is nothing in that build doc that suggests it should be any different. The only 4-knob pedals that I have built that has a different layout is the Tommy, but it has a switch and uses the 5/6 knob layout with the switch in one of the center spots. Build it. It will fit.
