Sabbath Distortion
BuddytheReow
Breadboard Baker
Hey guys,
Just finished the circuit on a sabbath distortion. I alligator clipped it to test and I get virtually no signal coming through. The signal that does come through is incredibly faint and sounds not distorted. The pots appear to sound correct (volume, gain, etc). I did test the pots before soldering them in. Here are the voltages for the trannies, pins reading left to right:
q1 0 2. 8.7
Q2 0. 1.6 3.7
Q3 2.9 4.8 8.8
Q4 0 0.6 4.2
Q5 2.9 5 8.8
Q6 2 5 8.8
Any assistance would be greatly appreciated. I know I can count on you guys to help with this.
OK. I've boxed it up and tested it again. The effect works, however I'm still having these gain issues where I hear a warble. I've linked 2 videos below with my daisy chain power supply. One video is only this pedal plugged in and you do hear the grounding noise. The second video I have multiple pedals plugged in, but not engaged and the grounding noise is cleaned up. See below link where I talk about this.
The work around is I simply don't turn the gain to max, but I don't think it should work like that. Can anyone assist?
Like this, youll most commonly see it in your guitar patch cables. The outer braid goes to ground while your inner wire is for signal. I usually run them from the switch to the jacks with ground attached at the jack only, helps keep down interference in some situations.
Double check the value of C12, I see a 4 on top of it, can't read the value though. It should be a 2u2. Not sure what the 4 is for.
It’s a 2u2. The “4” that you saw was a temperature range. See pics.
I sanded down the enclosure where the jacks touch and doubled checked my socketed items. All are good, but I’m still getting the gain warble starting around 3 o’clock. I guess I’ll just have to live with it unless there’s another thing I’m missing. Maybe in my next tayda run I’ll look for shielded wire.
So, I've been playing around with the pedal and I think this has to do with grounding issues, particularly in my daisy chain. If I have all the power sources plugged in to the various pedals the gain warble virtually disappears. This may be a one time "fix", but I will try it again later this evening and see if there are any changes. I'll tag this as 'solved' if this goes away. I will also try swapping out the 47pf cap too just in case.
Maybe your C10 47pf cap has become unstable/microphonic. I really hate those little red disk caps and recommend you buy the yellow MLCC style, but for now maybe try swapping it out.
I noticed the dinky caps for the 47p, is a good rule of thumb to use MLCC in high gain situations? Or just whenever at all possible?
Also i want to make sure about the shielded wire thing as i have a sabbath to complete: the hot goes from switch to jack as normal, while the cold goes from switch ground to just being terminated at the jack, not attached to anything, on both input/output? And there shielded wiring available in 22/20 gauge?
Thanks for the info, its good to know that theres a few additional things to pay attention to when building high gain pedals.
I haven’t touched those little disk caps in years, MLCC or better for me.
As for the shielded cable hot goes to jack tip and switch, cold to jack sleeve or another ground point, easiest to get it on
The jack. I believe I have a spool of RG-174 cable that works well, I’ll double check when I get home but it’s 24 or 25awg on the inside. It’s not a cure all for noise but it’s helpful in cases where the input wire is running close to an LFO or opamp like in the Phase II.
