The K is for the cathode (Kathod?) which is where the flat side of the LED goes. This particular picture looks like you need to solder it in. You can test your LED with your DMM. Put it in diode mode and touch the black probe to the cathode and the red one to the other side. Also, if you have the input ground wire on the wrong ground lug, you’ll need it on the right one.
