Scenario Overdrive Pedal
music6000
A Great Soundung Pedal, leaning towards a Dumble Steel Stringer than the Overdrive Special!
Mod: 9mm pot soldered to the reverse side of the trimmer so BASS pot is adjustable from the top.
In House Graphic on a unpainted 125B, finished with Automotive Clear Coat.
Apem KNS501BA1/4 Knobs.
Wow! Looks awesome! I just mentioned on another thread on here about doing the bass externally!! Is it in reverse as in turning cw subtracts bass?
The 9mm pot is mounted above the trimmer pads.
It works as normal, Clockwise increases Bass.
Note that the pot has the 4 plastic standoffs & metal claws cut off.
The hole in the enclosuree needs to be precise to support the pot.
I measured from the 2 outer legs to the centre of the black pin :
