I'm not 100% sure but I think both are designed with the LT1054 in mind. Generally if you use a 1044S or 7660S you'll need to connect pins 1 and 8 in order to not get an audible whine in the circuit. In the Simulcast, those pins are not connected. You might be able to get by with creating that connection yourself as it's not on the PCB and using the 1044S, depending on how much current is needed.Simulcast / Duocast - LT1054CP or LT1044SCPA - which is better?
I have some of both - any reason one is better than the other?
The Simulcast and DuoCast both have solder jumpers on the back of the PCB to connect pins 1 and 8 if you want to use a 1044S or 7660S Just bridge the connection with a little blob of solder.
Yes I think I got this one on a recommendation from another internet group: 42TL218-RC
Haven't tried it because I still need to get the germanium transistor. God this circuit is a pain for sourcing parts!
